Tourmaline Healing Properties
♥ Flexibility ♥ Happiness ♥ Objectivity ♥ Compassion ♥ Serenity ♥ Balance ♥ Positive transformation ♥ Healing ♥ Strength ♥ Tolerance ♥ Understanding
Tourmaline is a crystal silicate mineral. Tourmaline is an 8th Anniversary gemstone.
Chakras - (depending on colour)
Zodiac - Virgo, Libra
Typical colours - Most commonly black, but can range from brown, violet, green, pink, or in a dual-coloured pink and green (watermelon).
Tourmaline aids in understanding oneself and others. It promotes self-confidence and diminishes fear. Tourmaline attracts inspiration, compassion, tolerance and prosperity. It balances the right-left sides of the brain. Helps treat paranoia, overcomes dyslexia and improves hand-eye coordination. Tourmaline releases tension, making it helpful for spinal adjustments. It balances male-female energy within the body. Enhances energy and removes blockages.
In addition to the generic healing properties of Tourmaline, specific colours have additional attributes:
Black Tourmaline - also known as Schorl
Chakras - Base Chakra
Zodiac - Capricorn
Element - Earth
Black Tourmaline can be used to both repel and protect against negativity. It is excellent for deflecting radiation energy. It enhances ones physical well being by providing an increase in physical vitality, emotional stability, and intellectual acuity.
Blue Tourmaline - also known as Indicolite
Chakras - Throat Chakra
Zodiac - Libra, Taurus
Planet - Saturn
Element - Water
Brown Tourmaline - also known as Dravide, or Dravite
Zodiac - Aries
Brown Tourmaline is used to clear and protect the aura. It clears and opens the earth chakra, (which is located approximately 12 to 18 inches below the soles of the feet - it is not within the actual physical body but is part of the etheric body), grounding you to the earth. It assists in healing dysfunctional family relationships, and helps the user feel comfortable in social groups. Can be used to to treat intestinal disorders and skin issues.
Green Tourmaline
Chakras - Heart Chakra
Zodiac- Capricorn
Planet - Mercury
Element - Earth
Pink Tourmaline - also known as Rubellite
Birthstone - October
Descriptions of the healing properties of gemstones are from the following sources:
- "Love is in the Earth : A Kaleidoscope of Crystals
" by Melody (I highly recommend this book);
- "The Crystal Bible Volume 1: Godsfield Bibles: A Definitive Guide to Crystals
" by Judy Hall (I highly recommend this book);
- My own experiences and observations of gemstones.
