Cleansing, Programming & Cleaning Your Crystals & Gemstones
All gemstones, and gemstone jewellery, purchased from Charms Of Light are cleansed and Reiki enhanced before they are sent to you. However, over time, they will pick up negative energies or vibrations and will need to be cleansed again and re-energised. You may also wish to programme your gemstones with specific healing intentions, once they have been cleansed. Cleansing your gemstones is also important before making a gem elixir. Following are a few suggested cleansing and programming methods, along with some instructions for cleaning your gemstone jewellery. To ensure that your special “Charms Of Light” remain as clean and full of energy as you receive them, please follow one of these recommendations. If you have any further questions, please feel free to contact me.
Cleansing Crystals & Gemstones
Reiki
Reiki energy will cleanse and energise your crystals.
If you are Reiki Level 1, simply hold a crystal in your hand and Reiki it. If you are Reiki Level 2, you can also use the mental/emotional symbol over your crystals.
The Moon
A full moon and a new moon are especially powerful for cleansing and recharging your stones. You can place them outside or on a windowsill at these times. Even if it is a cloudy night, the moon's rays will still energise the stones.
The Sun
The sun is also a very strong energetic way to cleanse your stones. Even when it is cloudy, the sun's rays will still energise the stones. Be careful though, as some stones will fade in the sunlight.
Mother Earth
Gemstones & Crystals come from the earth, so placing them directly into the earth will naturally cleanse all negative energies and re-energise them. I suggest you leave them for approximately 24 hours. If the stones are set, or strung into jewellery, it is best to gently cover them with a cloth first, so that small bits of dirt don't get into the fastenings etc.
Running Water
Holding your gemstones under clear, purified water will cleanse and recharge them. Do not use ordinary tap water. Some stones should not be immersed in water, so if you are unsure whether your stones are water safe, use a different cleansing method.
Sea Salt
Sea salt has long been known to have purification properties. For this reason, many people like to place their gemstones directly into a bowl of natural sea salt, however I find this to sometimes be too harsh on the softer stones. Instead, I use two glass bowls - one larger than the other. Fill the large bowl with sea salt and place the smaller bowl into this. Put your stones into the small bowl and leave overnight for approximately 24 hours. The sea salt will absorb all negative energies from the stones, leaving them cleansed and re-energised. Make sure you dispose of the salt so it is not used again. Only use glass bowls when cleansing and charging gemstones with salt.
Salt Water
Again, (as with the sea salt method), I find this to be harsh on some of the softer stones. Only use this method on harder stones, and (as with the running water), if you are unsure whether your stones are water safe, use a different cleansing method. Place some natural sea salt into a glass bowl, add purified water and your gemstones. Leave for approximately 24 hours and then gently pat dry, or leave to air dry.
Rice
You can place your stones in a bowl of brown rice. Make sure you dispose of the rice afterwards.
Smudging
Smudging is a very efficient way of cleansing gemstones. You can use sage (white sage is popular), sweet grass, sandalwood or even incense to smudge your crystals. Simply burn the smudge stick or incense and pass your stones through the smoke. This will clear the stones of all negative energy.
Singing Bowl
If the stones are small you may put them into the singing bowl. Place bigger stones close to the bowl, then set your intentions and play the bowl for a few minutes.
Using Your Intention
Focus your mental energies on your crystals and ask the Universe, or your Angels, to cleanse the stones of all negative energies and to re-energise them for their maximum potential. Always thank the Universe, and/or your Angels, after doing this.
Other Crystals
Placing your stones on a large quartz cluster will clear negative energies and re-energise the stones. However you must remember to regularly cleanse and re-energise the quartz cluster to ensure it retains its cleansing and re-energising powers.
Which Crystals Are Water Safe?
Some crystals are perfectly safe to cleanse in water, however there are many that are not. Crystals that are very soft tend to scratch or flake easily, whilst others contain metals and/or toxins, causing them to rust or become toxic. The following, more common crystals, are considered safe to cleanse in water:
Agate, Amethyst, Aventurine, Clear Quartz, Citrine, Red Jasper, Rose Quartz, Smokey Quartz, Snow Quartz, Tiger Eye
Programming Crystals & Gemstones
While it is not essential to programme your gemstones to gain benefit from their healing properties, you can do so if you wish to focus the stones' energy on something specific. To do this, I suggest following these steps.
Step 1
Think about what you want from your stone and carefully formulate your intention.
Step 2
Choose a stone that resonates with the intention you desire. For example; choose a calming stone for letting go of stress; or an energising stone to promote action. You can use the gemstone healing properties listed on this website for guidance, or your own intuition as to which stone would best serve the purpose you have in mind.
Step 3
Cleanse your chosen stone (or stones) with whichever method you prefer. I also suggest that you clear the stone of any previous programming while you cleanse it.
Step 4
Sit quietly, hold your crystal and clear your mind of unrelated thoughts. Start to focus on your intention. You may state your intention out loud, or visualise the words of your intention - whatever you feel more comfortable doing. Repeat your intention several times until you feel the vibrations have been absorbed fully into your stone. When you intuitively feel that the process is complete, it is.
Everyday Use and Care of Gemstone Jewellery
Most gemstone jewellery is fairly durable, but some care does need to be taken.
- Remove jewellery before doing any housework - household cleaners are corrosive and may permanently damage your gems;
- Remove jewellery before doing any manual labour; or work requiring hands to be immersed in water.
- Remove jewellery before swimming or showering - chlorine, some soaps and just immersing in water, may cause damage to your gemstones or their settings;
- Remove jewellery before sleeping - tossing and turning in your sleep puts excess strain on your jewellery, causing it to become loose or even break;
- Only put on your jewellery after perfume and/or hair care products have dried - these may cause breakdown of the stones;
- Store in a dark place, out of direct sunlight, in a pouch, ziplock bag, or jewellery box - sunlight may cause fading of some stones. and the humidity in the air can cause tarnishing to silver.
General Cleaning
If your macrame jewellery requires cleaning, you can use some mild or diluted liquid soap on the cord only, on occasion. Make sure you rinse the soap off quickly with cold water and dry the cord by pressing between a soft towel to remove excess water.
Silver can tarnish quite easily, leaving it looking black and dirty. To ensure that your silver is kept shiny it can be polished gently with a jewellery cloth, or you can use a standard silver polish.
Copper is likely to develop a distinctive patina. Patina is not a "defect", it is a natural by-product. If you do not like the patina effect, you can clean copper goods using standard copper polish.
TAKE CARE using polishes and tarnish removers around your gemstones, as these can cause your gemstones to become dull and fade.
A soft cloth can be used to wipe over all your gemstones. As some gemstones are more sensitive to getting wet than others, it is always better to keep them dry as much as possible.
